Why is it that when we put spacers on single wheel axles front or rear we say for safety reasons that the vehicle should be for trail use/ off road only?
But when we convert a single axle truck to a dually which increases the stability of the vehicle for towing very heavy loads, increases the wider stance and puts more leverage on the bearings this is ok for street use?
For example converting a dodge truck from single wheel axle to a dually they just bolt on front and rear spacers? Some axles have a little different configuration in stock form as a dually from the factory.
Are Steel spacers safer/better/stronger than aluminum?
Depending on where you live some states require a vehicle inspection at the time of purchase for title, some require annual and every two year inspections. So they must see these aftermarket conversions on single wheel trucks to duallys all the time.
So whats different? And why is one deemed safe and one is not?
Not trying to argue a point of right or wrong, just asking.
