Wheel studs
nedceifus
Nebraska
what is the Dorman part # for the longer 1 ton front wheel studs. I have the short ones & they work fine on my pressed steel wheels but now I need to run an aluminum spacer.
REPLACEMENT D60 WHEEL STUDS IN 3" LENGTH....Dorman #610-563 (9/16-18; 3" OAL; .658 serrated diameter)
http://www.ezaccessory.com/8_Lug_Same_Pattern_s/18840.htm
This site was recommended to me by my old tire shop in Moab. Looks like good prices and good products.
https://shop.advanceautoparts.com/w...ypeList&actionSrc=Form&searchTerm=wheel+studs
There's several different knurl diameters and lengths. I am just running rear dually studs all the way around on my blazer. The rear ones are from Napa and worked perfect but one or two have a loose fit in the pressed in part and my front ones are from CARQUEST and were too long so I had to trim them a little shorter. They also didn't have enough threads when I went to thinner steel wheels so I had to run a die down each one.
