Wheels, Axels, steering arms, much more!!!!!!!!!!
81jimmyslt
So Lake Tahoe (Rubicon), CA
Ok guys I finished my swap and now I have some parts I need to sell. Everything is in good condition off of my daily driver.
1) dana 44 0r 10 bolt steering arm for 4-6 inches of lift $35 -pending
2)dana 60 steering arm $20 -pending
3)2 chevy swaybars + bushings, brackets and bolts, both the same one off my 10 bolt the other off the d60 $15 each
4)10 bolt or dana 44 spring plates $15
5)81' 10 bolt open, w/ 2.73 freeway flyers, complete minus calipers $80
6)81' 12 bolt open w/2.73 complete, good brakes, $75
7)set of 4 15x8 6 lug chrome wheels with lug nuts, great condition $80 pictures in mywebshots
8)14 bolt spring pads and spring plates for under the axle uses square u-bolts $10
9)4wd sector shaft, anyone need it?
10)2 4wd pitman arms and bolts $15 each
11) spring plates for 12 bolt $10
12) u-bolt sets for the 10 and 12 bolt /forums/images/graemlins/yikes.gif use at your own risk $10 set
13) 2 adjusting sleeves for chevy 4wd draglinks $4
and thats it for now check some pics out at webshots
the arm will be about nine bucks to ship /forums/images/graemlins/thumb.gif
you are talking about the 10 bolt arm and not the d60, right? I assumed 10 bolt from your profile.
[ QUOTE ]
8)14 bolt spring pads and spring plates $10
[/ QUOTE ]
pics? how much for shipping to 46041
here you go
they are for they square type u-bolts as you can see shipping will be about $7, the two u-bolts are free if you want them if not they are going in the trash /forums/images/graemlins/thumb.gif
