elks
So last weekend hunting I noticed a little abnormal movement in my steering. Today I get the front end up and find that my passenger side tire to wiggle. Closer inspection indicates that the entire hub is wiggling. At any rate, I take things apart and find where the out hub nut was tight as hell. Get it pulled and the inner was loose. Before taking it all the way apart, I tighten up the inner nut and all movement gone. Things roll smooth etc.
I take a look at the outer bearing and the race. They look good, but what would I need to find/feel/see in order to determine replacement?
The bearings have not been in all that long, like 2,000 miles max and I really can't tell a difference between them and haw they were new. minus the grease etc....
Thanks a bunch. I am probably going to put it together and hunt this weekend, but am curious what to look for to determine replacement. The hub has never gotten warm at all...
