DavidB
...whether to replace all your rivets or bolt suspension brackets on in different positions, always use a bolt that has a shoulder - the part under the head with no threads - that passes thru the two pieces you are bolting together. The bolt will probably be too long, so you will have to cut off the extra, but having the threaded part of the bolt going thru the 2 pieces of metal will cause problems. It will fit loose and work the nut loose. On the flip side, make sure the shoulder isn't too long, which would make the nut botom out on the shoulder instead of pulling the 2 plates together. Stover or crimped nuts are the best.
Not a bad idea to cut it off than then beat the end of the bolt so it mushrooms a little bit which will prevent the nut from coming off if it works loose.
