same with flathead screws, I find em, they go in the trash, evil fastener!
Can I get an AMEN BROTHER!
Sorry, I have a deepseated hatred of those, especially flathead wood screws as used by my otherwise-very-talented-at-woodworking father
-- A
The number one reason for my desire for the sleevless connectors is so that i can crimp and then shrink over the crimp. I just like the metal on metal of the crimping tool on the connector i guess.
-- A
eh, I'll be devil's advocate and see how many "f*ck you's" I can stir up....bring it....
soldering is WAY overrated in vehicle wiring IMO.. it has it's place, but also has it's own quality pitfalls too... you wont see d*ck in the way of solder work, on the biggest of boats, certified by the CG...
the only thing I solder is circuit board and radar stuff... the CG wants the proper mechanical connection.. period... certain shorts can melt out solder...
I know that'll offend all the oldschool guys who swear they are "doing the best possible work"...
it's just not true.. soldering heat stress and corrosion are far more of a corrosion/fail issue than a failed crimp.. proper tool and quality products assumed...
and honestly, factoring in a "money making biz" it's far from cost-effective.. soldering is STUPID time consuming...
Honest question. And what kind of damage can heat stress do? To be fair, I've had a couple soldered joints fail, but that was when I was first learning soldering, and I'm pretty sure I did a crappy job. And yes, it is stupid time consuming. And I've never used anything but the autozone standard butt connectors, so I'm sure that a higher quality connector (like with heat shrink on it) would perform better.
But solder won't really corrode if you've sealed it properly with heat shrink, right?Honest question. And what kind of damage can heat stress do?
Not gonna stir up any eff yous from me- I know exactly how much experience I have (which would be a fraction of yours, considering my age and that this is only a hobby for me, not a job). I'm always up for a good discussion.
Oh, and the corrosion problem? Yep, see that in electronics all the time. But its because someone used either the wrong type, or too aggressive a flux.
Ok, so this is going even more off topic, but I think the original question has been answered, so...
What do you guys do when you have to recreate an original factory splice where four or five wires of different gauges come together?
Well at least in my case, if you want to keep wire colors the same, it's impossible since you can't buy the factory wiring by the spool, at least not that I've found. Or, if you are trying to use connectors with pigtails when you don't have the proper terminals to re-do the connector.
