Have my HVAC system taken apart. Found the diverter valve link connector snapped in two. Imagine that...Also found the white plastic clip that connects the mode door rod to the blend door lever broken. The rod is on top of the suitcase. I've searched around and can't find it. Does anyone on this site know where to order hvac system small parts other than the dealership? I could get one from a boneyard but the AZ heat is not kind to plastic parts.
. I found a lock rod clip that might work for the sync rod above the suitcase, otherwise it's to the boneyard I go.
