where can i get add a coolant gauge sensor?
I dont remember exactly where I tapped into mine, but IIRC I removed the factory sensor on the front of the drivers side head and hooked in the coolant temp (could probably put in a T style fitting if want both) and then somewhere in the back (vacuum pump area) for the oil pressure.
i didnt get up in there and look yet.. i know where it is im just too lazy to putt my fat ass up in there the install it HAH.
I plan on doing this to mine as well using T's so I can keep the dummy lights. The oil pressure dummy light sender is in the head on the drivers side, between the head and the firewall.
