Where did my POWER go!?
I'm planning on replacing all the vacuum lines on my 87 5.7. What sizes do I need to do this? They re all pretty hard and crusty other than the ones that are away from the motor and they are cracked very bad.
I just pulled my vac lines off and took them and the adapters down to NAPA and worked with one of the guys there to determine which diameter hose I needed and they cut it to length. Mine were a couple different inner diameters so don't assume they are all the same.
That sounds good the only thing is this is the only vehicle i have right now. I'll just need to pull it all apart and see what all I need. I was hoping that most of it was all the same and I could just pick up a roll of it and piece it together.
Okay well I changed my thermostat out today and it didnt really change anything. It fixed my heating issue which may be part of it but still NO POWER. Vac? Am I really going to have to go through that mess?
