where do you buy th400 output & np203 input shafts?
RockinChevy
Chandler, AZ
I was searching for them last night, found a few vendors that sell the 32 spline 203 input shafts but no luck on the th400 output shafts.
I will be taking out the 454/th400 from the crewcab and into the Blazer with the ORD doubler.
Got any input on where to look?
your th400 should be 32 spline allready and your good to go i believe. You'll just need to use the adapter to the NP208 or 6bolt NP205 that was behind your 454/th400
You should be able to get what you need from ORD. I agree, you shoukldn't have to do anything to the TH400, and mounting the doubler depends on what you have, or need.
Which vendors sell the 32spline np203 input shaft? Anyone even close to reasonable on price?
I wanted my flat doubler (GM 203/Ford 205 combo) to be as short as possible and I have the 400/203 adapter already, I just wanted to grab the output and be done with it.
The TH400 output you need for the doubler is the shortest of the 400 outputs and they are comparitively rare. I picked miine up from a local tranny shop but someone like ORD or Northwest Fab might have the one that you need also.
Gus
We (ORD) have a few stock GM TH400/203 adapters in stock. They are used, but in great shape. Right now they are going for $125. We also sell brand new 32 spline 203 inputs $150.
Jon@ORD
Jon@ORD
Thanks Jon, I got those covered but I'm more after the th400 output for the 203, which is really why I started the thread.
