The electric fan on the front of my k3500 that's supposed to come on with the AC isn't kicking on anymore. I checked the fuse box under the hood and one of them says AUX FAN so I'm assuming that has to be it.
I checked the fuse for continuity and it's good. The rest of the AC system works perfectly.
I unplugged the fan and ran power straight from the battery and it kicked on and ran like a champ so the fan is good.
I traced the harness and found this plug...
If you unplug it and energize the left side the fan comes on so the harness from there down to the fan is good, including the ground. I tried to trace the right side of the plug but it's an absolute cluster of wires and almost untraceable without tearing apart all the looms.
I did try to do a continuity test between the two prongs in the fuse box and didn't get anything so at this point I'm trying to figure out where that right side of the plug gets the signal from so it knows when to turn the fan on?
