73blazer73
Registered Member
so I bought this blazer cheap and the PO had cut the wiring harness completely off just past the alternator and scabbed in a push button start to the starter. I ripped all the scabbed in wires out that were all over the vehicle and left it with basic wiring. So far I think I've got it figured out but I have no idea where the black wire goes. It comes from the firewall where all the other wires come out and just past the firewall it has an inline fuse in it. I checked it with my voltmeter and it's hot all the time with the same voltage as the battery. It ran the full length of the harness all the way past the alternator where it was then cut. The rest of the wires are as such....
Red- to battery positive, Came from junction on firewall
Purple- to starter
Yellow- to starter, Came from coil
Brown or tan- I think it goes to fuel sender
Black- (fill in the blank please)
She fires right up, gets about 14+ volts on the battery while running and has no drain on the battery. Lights work. I don't know where that wire goes.
Any input would be highly appreciated. Thank you.
Purple- to starter
