Where does this wire go?
bassackwards
Tennessee
I am hooking everything back up and can't remember everything and apparently I didn't take enough pics :doah:
First one is this single wire plug at the rear right of the engine (not the ground, I got it already)
Next is coming off the coil wiring area
I'm sure there are more mystery wires to come,
Check in periodically and I'll post them when I find them
On mine, the alternator is grounded to the motor. The positive goes from the stud to the terminal block on the firewall.
The red wire is a jumper for the fuel pump relay. The mystery solenoid is the fuel pump relay. Just leave it hanging...
This is a pretty heavy gauge wire that has this big naked ring and is in the vicinity of the alternator
There is no ground wire dedicated for the alt. Its probably the engine ground if its large guage and black.
Picture is zoomed in to close to really tell.
I think it is the hot that goes from + battery to alternator maybe? Does it have 2 wires under that nut? A heavy black one and a smaller red one from the harness?
I'm also having trouble with the bracket that goes behind the alternator and power steering pump then to the exhaust manifold bolts. It will not fit over the header tube. :1zhelp:
Mine has 2 wires on the alternator stud. Mine are red.
Mine has headers and I trimmed the bracket to fit, only using 1 manifold stud. Not the best pic, but its all I got atm.
I installed a stud, used a nut to hold down the header and 2 nuts to hold the bracket. I cut the bracket so it ony reaches the first header bolt.
