Where to buy TH350/NP205 coupler
CyberSniper
Chelsea, MI
Where can I get a TH350/NP205 coupler?
I lost mine on the side of the road. I have the adapter, the transmission, the transfer case, but no coupler.
well as luck would have it, I did find one by the side of the road the other day /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
seriously, check ebay...just search "NP205", there always seem to be 1-2 on there at a given time.
there are a couple of styles IIRC.
my extra one got sold on ebay a while back in the day of slush boxes. some go for decent $. crazy.
I bought a brand new one from a local shop near St. Louis, it cost me around 75 bucks. He had to order it from Minnesota.
GDS 4 X 4 & Drivetrain Service
24 Schiber Court, Maryville, IL 62062
(618) 345-4294
I bought a drivesleeve from 4x Heaven for $50...
800-800-1679 (NY)
A year ago I got a coupler for a SM456/NP205 (10 spline of course) from GM for only $35. I dont know if you could get one for the TH350 or not, but its worth a try.
The 2 TH350 to NP205's I had didnt use a coupler like the SM465's did(they look like a pipe with splines inside)--the ones I had joined the tranny shaft and the input shaft of the transfer case by using a ball bearing with splines machined into the inner race,the bearing was mounted in the adaptor with 2 snap rings,and had rubber seals on the bearing to keep the ATF and 90W gear oil separated. I have seen other ones that the tranny shaft slid directly into the input of the transfer case too.I wonder why GM used so many different cases,adapters,and tranny designs?? /forums/images/graemlins/confused.gif--their engineers must be easily bored I guess---. /forums/images/graemlins/crazy.gif /forums/images/graemlins/screwy.gif
You just failed to pull the coupler from the transfer case. AFAIK, all TH350/NP 205 combos use a drive sleeve.
TH 400/NP 205 does not.
Thats very possible--I pulled the transfer cases out to store them away until I sold them,never took the adapter off either one. /forums/images/graemlins/crazy.gif
i have seen a 205 adapter with and without bearings as diesel4me is saying. its been a couple of years when i cracked one in my rig. it was just a drive sleeve with a couple of seals. the one i replaced it with (350/205 combo) had a pair of bearings in the adapter.
