Where to find new spring perches?
BlazerBoy
Chicago IL.
Where can I find new spring perches for a 14 bolt rear. I know some of you guys have fabricated your own. I am not sure I want to unless they are expensive or hard to find. Thanks
BlazerBoy
<A target="_blank" HREF=http://www.geocities.com/generalblueballs/>http://www.geocities.com/generalblueballs/</A>
I got my spring perches (for a 2.75" diameter tube, approx 4.5" long, 2.5" wide spring, can modify it for a C14) from either Milodon or Moroso (forget). It's in their catalogue. You can also get them from Currie. Expect to pay roughly $15 for a pair, to me it's a good price.
--Rob
The ones I got were by Moroso from Summit.They are identical in size ,shape ,and thickness to the factory ones and they were less than $20.
<A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
So the ones for 3" dia. axel tubes work fine? I just looked through the catalog and it seems like that is all they have are for 3" dia.
BlazerBoy
I took a grinder to the stock ones and ground the welds off around them and beat them off with a 3lb sledge. It took a little bit of time tah just cutting them off with a torch, but I rewelded those back on. They are so much stronger than the after market ones I've seen.
1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
As long as the tube your putting it on is 3" in dia.I guess if it was a bit bigger you could grind it a little to fit.
Grinding the welds off of the ones on the axle and reusing them sounds like the best and cheapest way to go.
