Just as the title says. I want to find HP & torque numbers for a stock motor. Anyone know any web sites, thanks. Already searched.
What engine are we talking about, what year, and what vehicle?
Your engine had a 4x4 donor, but I don't believe that made any difference (?).
454 out of a 93' 3/4 ton chevy suburban, not sure if it was a 4x4 or 2x4.
That engine is listed as having 230hp @ 3600 and 385tq @ 1600
That info is for a 93 suburban with the VIN N 454 TFI engine (TBI)
A forged steel crank won't make any more torque at all than a stock one - it will handle more power and torque if you built the rest of the engine to produce higher numbers.
The limitations of the TBI engines were in the head/cam designs. If you take steps to get past these, you then need more fuel and can potentially max out the capability of the TBI fuel system (simply can't flow enough for huge HP numbers).
I think people get too wrapped up in HP/torque numbers on paper...while not a monster, that engine makes very good torque and power down low and is very reliable and will last a long time.
