im not sure on how much I need yet. Im thinking the cable to the battery isnt gong to change in length from where it is now but im not sure if im supposed to run it off the battery I have or the 2nd battery when I get it. I also have to figure out what the PO did and didnt do as far as the 12v swap. Can it be as easy as adding another battery and grounding and connecting to the 1st battery? I gotta figure out how the 2nd battery gets charged
Kennyw posted a good link and I need to really read it so I set this correctly.
A complete 12V conversion would:
- Change the starter, as they were 24V originally.
- Presumably remove the glow plug resistor (the GP's are 12V, right, but there's a ballast resistor thing to drop, IIRC)
- Remove the second alternator, which IIRC is the passenger side one.
- And have only one battery.
Assuming that's all been done right, then sure, you can just put a second battery in parallel with the first, + to + and - to -. This will get you more cranking power, but won't isolate them, so if you drain one you drain both. (Which is fine unless you have a giant stereo or lights or a winch or whatever you wanna run with the engine off. Anyway, isolators are a WHOLE other issue, read any of RootBreaker's posts in the last coupla weeks.)
As for needing anything bigger than #4 ... From my EE background, I'm suspicious. For a reasonable length (like 4-6') that stuff should carry enough juice. I'm wondering if folks who replaced their cables with bigger had corroded *old* cables -- i.e. were replacing a (bad) #4 with a (good) #0 cable. I think that replacing a bad #4 with a good #4 would do the trick -- but I'm talking theoretically here. Rene knows his stuff, so no argument there.
Ain't no matter to me, but when you replace the cables, strip the insulation off the ends and cut the middle somewhere, and see if you find any green stuff. I've seen battery cables corrode from the inside where you CANNOT see any indication on the outside, and yet when you open 'em up ... it's obvious why your starter wasn't getting so much juice
Now, it is POSSIBLE to fit two group 78's onto one CUCV tray, as they are fricken HUGE. It will take some fiddling and, IIRC, several feet of 1/4" allthread. If your current battery is some other size, then I don't know what'll go in there.
If it were me, since your truck is converted to 12V, I'd get rid of the CUCV trays (sell 'em on Ebay or post 'em up here) and get some normal civvy trays and put those in. I don't have my CUCV any more to look at (sold it, sniff!) but IIRC there's room in the front corners to put the stock battery trays.
It's a bit expensive, though obviously cheaper if you can find a good used set here or on Craigslist or at the junkyard. The benefit is that you get the battery out from the middle of the fricken engine compartment, so you can lean in and *work* on stuff more, and IMHO it's easier to wire around the edge of the compartment than having crap hanging in the middle.
And yeah, having two batteries on the diesel is good; also having good glow plugs. The Kennedy quick-heats are highly recommended; at least get yourself a set of the AC Delco 60G's or whatever they are (look in the diesel forum here for my posts, or anything tRusty said about it =)) I don't think you get any colder than we do in the winter, but mine was starting to really choke on the glow plugs that came with it. A new set and she'd fire up every time, even in the as-cold-as-we-get (which ain't much.)
I digress. Does that answer your question?
-- A
-- A
