Where to get cheap kingpin rebuild kits?
Do you need complete kits or just the bushings and springs? I have a new set of bushings and springs I bought from ORD that I ended up not needing if this is all you need. I am local to you also so no shipping involved. /forums/images/graemlins/thumb.gif
I got mine at partsmike and the inner axle seals and spindle bearings/seals from OffRoadUnlimited. I am planning on getting the inner and outter shafts for ORD and all bearings from Randy's ring and pinion when I order my gears.
That seemed like the cheaper (maybe not cheapest) way to go and they all have good customer service and have supported fellow CK5'rs for quite some time.
Best deal I found for a complete kit was at Randy's Ring and Pinion. It was forty-some bucks per side for a 60. I generally buy from the local NAPA, but they couldn't get all the parts that Randy's included, and they would have cost quite a bit more.
[ QUOTE ]
[/ QUOTE ]
I have the Spring and bushing (unless I should replace them) I just need the retainer, bearing and seals. Maybe ill just get these lose parts, instead of getting a whole rebuild kit.
