emoo99
So I just put some 10 degree shims on my 14 bolt and now the pinion is pointing up towards the t-case about 15 degrees up. I read a lot about the pinion bearing needing to be submerged(or atleast needing to see oil consistently). So I plan on tapping my oem cover up high for a fill plug to get more oil in it.. I've converted a small spray paint can into a "overflow" for the breather tube so it won't spew fluid out. How high up should I put the plug? Is there a problem with over filing the housing causing aeration or anything? I'm not concerned about expansion of oil cuz of my overflow tank so can I just get this plug as high as I can on the diff cover and pump it in there?
