mtnman210
I've been looking over a ton of threads on tapping a steering box for hydro assist. I'm thinking that just doing the two holes on the box would be the easiest. However alot of what I've read has said that tires will hit the fittings when in that position. So is there another spot to tap the box where you won't get the tire clearance problems without going to an end cap.
The other option would be an end cap. With this setup where do you tap your box?
and one final question....where you I be able to find a 1/4" 18 thread NPT tap? Can I get one at say Lowes or am I gonna have to order it?
