emoo99
i replaced my steering wheel with a grant a little bit ago, where the contact plate makes contact to the wheel it doesn't ground out because the grant wheel is painted, so i took it off and sanded it down.. the ground(horn) wire touched the center splined hub(nut) and the horn sounded for a second, then went out.. i have 2 bad boy electric horns in replace of my factory horn so it's pulling alittle more juice but not much..
1. i check the fuse (still good)
2. i replace the relay(still no horn)
3. i hard wire the horns(horns work)
4. i test voltage at the horn fuse at the panel.. and get 12v on both sides
5. i pull the horn relay(3 pin) next to the hazard flash and get 12v on one pin, ground on one pin and that leaves me with the other pin connecter supposed to go to the wire at the steering wheel (i assume).
6. so i continunity check from the horn wire to the pin and nothin.
i have a feeling somewhere in the column i've lost contact with the wire or it came loose or melted in the column somewhere.. i want to continunity check different parts of this wire
..so my question is... from the steering wheel where does this horn wire come down under the dash so i can continuity check it? anyone know what color it is coming from this horn relay panel and if it's the same color going all the way up the column(black)?
