BlitzK5
Getting a bigger pan for my TH350. Should I go with the cast aluminum or the chrome steel. I would think the aluminum would give better cooling but it could dent easy, And the steel will not give off as much heat but would be stronger, It is also cheaper to. What are you guys opinions on which one to get?
