which bolts for steering brace?
stoney126
napa,CA
hey all I got a ORD steering brace used. I need the bolts for it. Which size am I looking for ? Thanks for any help
Thanks for referal Jishory. I was just out your way over the weekend. If you're going to the BranndonC BQ, I can bring them.:D
Edit; they're 7/16-14
would I be able to reuse these bolts? I ask cuz down the line I plan on getting a weld on brace as well. Just need the 3 and the 1 right?
Yes, done correctly they won't stretch. The bolts work with or without the welded plates.
Yes, just the bolts threaded into the steering box, benefit from the Grade 9. The other bolts use nuts and washers and are very lightly loaded.
is it just me or does the weld in plates seem a little flimsy? I dont think its thicker than 18ga... at least the ones I got from 4 wheel parts...
ORD plates are .155 thk.
