Which brake cables for 14 bolt disc/ebrake conversion?
elyon
Eastern NC
I just converted my 14 bolt to disc brakes with integral ebrakes. Anyone know which cables to use for a 1986 Suburban?
Which brakes are you using? The cadilac style calipers or the AAM 14B with the e brake inside the rotor?
Fairly sure that most of us have used the factory ebrake cables, and just welded a tab to the axle to hold the cable sleeve. I was able to do this and then adjust for overall length/holding power with the built-in adjustment mechanism on the 70's style cable system.
