Ok so I climbed up into the engine compartment and looked at the spot shown above. I can see there are numbers there but it looks like there aren’t that many or they are almost worn off. I cleaned it with a rag and a tiny bit of soapy water. Even viewing from six inches away with a bright LED flashlight, I can barely make out just a few numbers. Is there a chance they are worn off? Or is there a product I could use to make them more visible? Is it actually dirty and in need of a solvent to clean? To me it looks like I have it down to bare metal and the numbers are just so vague. Ideas?
..By dip you mean the solvent that is supposed to melt everything off and give you a shiny new aluminum casting?it is a quadra jet 4ME, the kits will have the gaskets you need, the spec sheet might not have your carb settings. also buy a float. you will probably need a small amount of 2 part epoxy, if well plugs are leaking. the newer carb dip doesn't work that well, and the q jet bowl, throttle plate assem, don't fit well in a gallon dip can. I use plenty of spay cleaners and compressed air these days.
Your mentor may have his own method, and be able to help the specs.
Yeah epa made them crap.
I had a 5 gallon bucket of the old stuff bout in 2002 but when it sat in the shed for a few years when I was not using it the container rusted out and the fluid evaporated
