In the old days, there was only one. Then GM changed things up with their OAT formula in the mid 90's. Some say it's junk, others say it's fine.
Ford and Chrysler specify yet another coolant, G-05 a HOAT formula. (Hybrid OAT).
It seems the Dexcool stuff GM has been using contains an ingredient called 2-EHA , which from what I read , doesn't like air. The fact that GM has switched to a pressurized coolant bottle with the rad cap there instead of on the radiator, is proof enough of that, that and their TSB's on various customer complaints about dexcool gumming up has boiled down to an air leak somewhere, like a loose or ill-fitting rad. cap .
I've done extensive research around this for the last couple months. Read ALOT of techical articles, I'm still somewhat undecided as to which coolant I should really use in my Cast-iron RamJet engine, with aluminum radiator and alum. heater core. I've had Dex-cool in my 1970 impala with original 60kmi 400sbc engine for 4 years now, still looks perfect. I only used it because I had a fleet of newer GM vehicles that specified it and I didn't even think twice about it at that time. But I don't think it has an issue with air in that car, there's no overflow bottle. so any coolant exposed to air is simply expelled out to the ground and not re-introduced to the system. In my K5, there's an overflow bottle (I don't particularly like dripping coolant on a hot day after you shut your car off).
G05 is low silicate, which implies lower protection for alum. radiators. ,it does have a decent phosphate does (which I think is good protection for alum?) although it says it's fine for alum & cast iron parts.
Green stuff is supposedly bad for bi-metal engines, turns into a battery pretty quickly, from what I gather.
I'm somewhat inclined to go with the G05 stuff, but it does not meet any GM specification. These Ramjet engines are same parts, seals, gaskets and all, for lots of late 90's early 2000's GM engines before they got rid of the old SBC block for good. So I'm a little afraid the G05 stuff may not play well with certain seals and whatnot.
So, what do you all use for any cast-iron alum mix in your cooling system?
