which diff setup should I use a corp,14 bolt rear& a 60 up front or Dana 60s front&rear im running 33's right now and killing 10 bolt not evan driveing it hard
I would run the 14ff out back if you don't need anything more than 5.38 gears. The reasoning is that there are plenty in junk yards IF you ever needed to find parts.
If you plan on keeping the 33s I would run a 9" ford. But with the given choices probably a 60 I am pretty sure they have a bit more clearance than even a shaved 14b
