vindemiate
Registered Member
A few weeks after I had a 6" lift installed my rear driveline started to shudder when depressing the skinny pedal. Took it to a shop and was told the pinion angles were off. OK. I purchased some shims and installed them and walla... still shudders. After inspecting closely, I found the front U-joint was toast.
I was planning on having the driveline extended anyway to account for the lift but now I was thinking of replacing the whole thing. What would be an appropriate driveline for a 90' K5 with a 6" lift? I want to run 35"-37" tires and do modest trail driving. No rock crawling.
Also, if I plan to move the axles out another inch to inch and a half, would the axle have to change again?
