Which drop pitman arm?
smith45acp
Registered Member
I have an 87 with a 6" lift on 35's that needs some steering geometry adjustment. It has all stock components now
My mechanic (who is fixing other things) says I need a 2" drop pitman arm.
4wheelparts doesn't have one, they just have the raised steering arms
Where I can find what I think I need, they're asking $120 for it.
Does this seem high? Anyone got a good source for these that might be cheaper? I was expecting to pay about half that much.
Thanks all
Summit Racing has them online. I got mine from Classic Industries. You might be able to find one in the classified section here. Google "chevy drop pitman arm" .
There may be a better correction for this and hopefully they can chime in. I corrected my steering temporarily with a drop drag link and drop pitman, only because I couldn't get my old steering arm off.
you should get a raised steering arm and a drop pitman arm, so your draglink is parallel with the ground...
act slight drop to the back is best.
i tryed to correct with both on 6" lift and it wouldnt steer worth a crap in a parkinglot let alone on the street.
Look on this sites For Sale forums. I see an arm listed every now and then for sale. And cheaper than you can get them from name brand stores.
