Which energy suspension bushings...
Ultimate CC
NY
I want to replace my tranny mount and motor mounts with some energy suspension ones...i have a 83 chevy k10 stepside with sm465 and np208...
3-1106R- tranny mount but it says its for automatic, is there one for the manual?
ENS-3-1116R- motor mount, this seems to be the right one...
Then there is also 3-1130R which is the combo but it seems to be for an automatic as well?
I just want to make sure I have the right ones before I go and order them.
Dan
I've got an '85+ setup, which uses different mounts, however when I talked with Summit, I was told that the "kits" did not fit manuals, and I'd need to buy the (much) more expensive transmission mount for a manual separate. IIRC the trans mount for mine was $60, more expensive than the entire trans/engine kit for an automatic setup.
do you happen to know what the part number for the manual is, i don't see it on summits site
I believe for you its this:
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]1968-84[/FONT] [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Transmission Mounts (2 per set) For K5 (Blazer), K10, K20, K30, Suburban[/FONT] [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]3.1106[/FONT]
I'd talk to the vendor before order though.
Taken from the (almost) bottom of this page:
http://www.energysuspension.com/pages/c4wd1.html
