putting roller rockers on stock heads with a small cam "260 grind" is pointless in my opinion, first off roller rockers do operate smoother, but do you really need them, the roller tip and rolling bearing in the fulcrum are only needed with lots of lift, high rpm, higher then I think you may intend, also clearence for bigger valve springs. dude spend your money whereit counts and will make a difference, intake, I run an rpm and it works great, headers, cheap and make a big difference, a carb, personally I don't like quadrajets but run whatever you like, timing chain can be a good upgrade along with a cam for the stock chains get sloppy with a lot of miles greatly affecting performance
