dave w
The answer depends on the Histogram. The picture below shows rich fuel mixture at low Kpa, but lean fuel mixture at high Kpa. In the case of the picture below, a Vacuum Fuel Pressure Regulator is better because at high Kpa the fuel pressure will be higher to increases injector flow and make the fuel mixture rich. At low Kpa the fuel pressure will be low to decreases injector flow and make the fuel mixture lean.
If all the Histogram cells were all green or all red, then an Adjustable Fuel Pressure regulator would a good choice. When the histogram is all RED, the adjustable pressure regulator would be set to lower the fuel pressure to lower injector flow. When the histogram is all GREEN the adjustable fuel pressure regulator would be set to a higher pressure to increase injector flow.
The screen shot is from the first data log of a rebuilt TBI 5.7 liter with an aftermarket 4x4 type performance camshaft.
dave w
dave w
