Which is better mechanical or electrical oil pressure gauge?
For 78 I have the electrical oil pressure gauge. If I can get the mechanical gauge and cluster would it be a bolt in? Would it be worth the effort to go from electrical to mechanical?
I don't remember if they changed from an amp gauge to a volt meter the same year that they went with an electric oil pressure?
My 1977 K-10 came with a mechanical oil gauge and a voltage gauge - the truck was a very late build date of 08/77.
Can’t recall when the AMP/Volt switch over was ?
had both mech and electric with problems .
its all in the quality of the guages and the products used in them getting there signal .
mech only use copper line . had nylon brake and dump hot oil on a buddys boot going down the road .
have had electric senders start leaking that were old . . aged out .
had a cheep set of guages in a friends can show 40psi oil all the time ....... mechanical and frozen . found out when motor was ticking from 16 lifters clattering .
Personally, I wouldn't want fluids in the cabin, if it could be avoided. Esp, in the case of bad things happening.
