i'm going to apologize in advance for the long post. So in december i bought a fully loaded 86 blazer that i thought was in good condition ( bought from a friend and by the time i got to looking at it i was freezing and did a quick look through) i knew it needed a new transmission as reverse was shot but the engine was a crate motor 305 with 40k on it. it ran fine and everything worked except the power steering was shot. i knew the floor on both sides needed to be replaced. but digging further found the frame was rotted out behind the rear shackle and part way into the shackle mount, the cab mounts were rusted out the tailgate support, the lower quarter panels on each side also needed to be repaired. the good of it was the interior was in good shape and all the wiring was done right.
so i decided it wasnt going to be cost effective so i'd pick up a new one
2 weeks ago i picked up an 84 that i knew had some issues but seemed to be over all good shape and the things wrong i figured i could pull off from the 86. this one had a 350 swapped in with supposidly 70k on it but does appear in good shape, does need a tune up. has a 4" lift with 35" tires. i knew it need floor and rocker panels on the passenger side and needed to have the radio wires fixed as someone stole the radio from it before it was put up for sale. so far i have found the following on top inner and outer rockers need replacing on both sides, floor on passengers side needs to be replaced, as well as both rear corners of the floor. the dash metal has been hacked up quite a bit but not beyond being able to use it, one of the previous owners mangled the air tubes behind it pretty good. i also need to swap in the ac system from the old one.
i have the welder and skills to weld in fresh metal, though i am currently lacking an aircompressor and sand blaster but looking to resolve that soon.
My question is which one is the better one to fix? or should i just sell both for parts and move on to the next one?
Thanks in advance for your thoughts/ comments
