Which rear axle for Trazer build-poll-
Which rear axle for Trazer build*poll*
  • Total voters
    20
jones
IONIA,MI USA
D60ff SRW,4.11,LSD
14bff DRW,4.10,open
I'm nekkid drivin' a Jeep
The front is a D44 4.11,open that is the match to the rear 60.I don't want to re-gear.Besides,the difference between 4.10 and 4.11 isn't enough to worry about...right:dunno:
the 4.09, 4.10, 4.11 etc isn't enought to even matter. If you plan on going down to like 6 or 7 ratios then stick with the 60 rear otherwise I would run the 14 for the ease of gear instal and cheap detroit or weld job
jones said:
D60ff SRW,4.11,LSD
14bff DRW,4.10,open
That 14bff drw is probably out of a cab and chassis truck and its gonna be real narrow. just to let you know, ya might be better off getting a 14bff out of a 3/4ton truck or 1-ton srw truck, or even a 1-ton van
There are also wide 14FF that came in the C30s. Same width as a DRW Dana 70. They are rare to come buy I have only seen them under trucks on the road none in the JY:o . Like was said if you plan on going deeper than 5.13 then I would opt for the 60 but if you intend to run a 60 front in the future I would go with the 14FF if it is the wide version to facilitate running stock H1 wheels:D
Ira
