As far as the heads go it will either work or I will be having some not so kind words with the machine shop. This was discussed at length with him before he picked the parts. He said he builds these same motors all the time and they run fine on pump gas and stock ecu. My motor was bored .40 over. The cyclinder walls were crap, high mileage motor that was not ever taken care of.
I'm in the same boat. Would like to know how the compression ratio works out for you... I know flat tops are available in different compression ratios, so i'm hoping my machinist knows more about this stuff than I do... Sitting on a .060 over short block -1989 with flat tops in it.(.060? yeah whatever, spare block sitting around, has all the roller cam provisions I wanted and I got to start building my motor before the old one came out...) I think all of my heads are 193 castings, all out of 1/2 ton blazer and suburbans, or 3/4 ton burb...
Machinist swore this would land me at about 9.0 to 1 on compression...
Plus my back hurt after removing all that crap last time.
