Ok, I got a th-350 rebuilt, balls to the wall with a reverse manual valve body(compression braking in 1st and 2nd). It's going behind a bone stock tbi 350, later that will be replaced with a built small block in the 400 hp range. I'm also running a 203/205 doubler. The trans guy recommended a 2200-2500 rpm stall, I thought that was kinda on the high side. I was thinking 2000 at the most
But maybe im crazy, I'm new to this.
What do you guys recommend?
But maybe im crazy, I'm new to this.What do you guys recommend?
