So I'm at a crossroads. My '90 has the stock 350 TBI with a 700R4 and NP241. I swapped in a NOS CUCV D60 loaded with 4.56s in the front. The 3/4 ton 14BFF I put in the back has 4.10s currently. I've got a brand new set of Yukon 5.38s in the garage (without the gouges on the pinion snout
) for the 14BFF.
The original plan was to get a matching set of 5.38s for the D60, add a big tranny cooler, and run ~39-40" tires with the stock motor/tranny combo until it dies. After thinking a little more about it, and considering the money to swap gears in both axles versus one, I am wondering if the logical course of action wouldn't be to get a set of thick 4.56s for the back to match the front, and run ~35-36" tires.
I've got the DIY4X shackle flip on the back with X-tied 6" shackles and zero rates, and plan to run some 4" TCs up front with zero rates there too. Possibly add a 1" BL for a little extra clearance. I have already trimmed the driver side front fender (looks about like the gray/white CK5 UA Vehicle), and will be matching the passenger side soon.
I won't be doing any rock crawling, so the flex part of it doesn't scare me away from the bigger tires in terms of sheet metal/tire carnage, but I wanted LTBs, and those are apparently unobtanium these days. I considered PB Rockers, but they are almost too wide for my taste and I've seen mixed reviews on performance in sticky GA clay. Either way, I can't run either one unless I regear both ends, which is significantly more $$$$.
So with all of the blabbering out of the way, what would you do if you were me? Buy one set of 4.56s and run a smaller tire, or regear everything and run a set of tires that in reality is only about 4-5" taller but looks a helluva lot better (to me), and offers a little more ground clearance?
) for the 14BFF.The original plan was to get a matching set of 5.38s for the D60, add a big tranny cooler, and run ~39-40" tires with the stock motor/tranny combo until it dies. After thinking a little more about it, and considering the money to swap gears in both axles versus one, I am wondering if the logical course of action wouldn't be to get a set of thick 4.56s for the back to match the front, and run ~35-36" tires.
