which way does a pilot bushing go in?
slowk5
gladstone oregon
Kind of a stupid ?,but am new to manual tranny stuff.The pilot bushing has a flat side,and a taperd side? any help will be great thanks.
taper toward the crank
the taper is to help center the bushing while you drive it in.
people like lakewood offer a bearing to replace the bushing , but i've never used one
if you plan on using the truck for anything other than pavement, pass on the pilot bearing, and use a bushing. dirt will eat the rollers.
the flat side goes toward the motor, the tapered side goes toward the tranny. the taper is to help the inputshaft in the hole. if you put it backwards, you have to have it perfectly lined up to go in.
taper toward the crank. the taper is to help center the bushing while you drive it in.
Sorry. Try again. :doah:
We have a winner! :D
WHAT?!@#! this is important. I thought roller bearings were better. , but your telling me its not?
Beater is correct. I remember reading simular statements to this effect going back as far as 20 plus years ago in the wheeler mags. Roller bearings are great for street cars though.
if the bearing was sealed from the elements, then sure a roller bearing is better. since they're not sealed, they're better avoided for offroad applications.
thank you everyone for all the input,it makes my life so much easy when i do it right the first time!
