which welder is better Lincoln 140t or lincoln 140c?
IIRC, the "t" model has amperage presets, while the "c" model is variable amperage, which gives you a bit more flexibility. If they're the same price go for the 140c, otherwise you probably won't notice the difference.
Where's the description, btw?:D
For the same amount I can get the Lincoln 175. Should I just go this route?
Will I still be able to weld on the body panels with this without destroying it?
That depends more on you than the machine:D. Output range is 30-140A on the 140 and 30-175A on the 175, so your low heat is the same.
I'd like to see a place where the Lincoln 175 and the Lincoln 140 are the same price. Around here it's about a 20% price difference. Go with the 175 for sure:D
get the 175 plus if you get it.
You can get both of them for about the same price on ebay. Not the same but if I don't buy lunch 2 days I can get the 175. Only a couple of bucks difference. I just saw a couple on them before I posted here.
OK, The sp-175 plus is a lot more than the 175hd. Should I just go with the 175HD for $450 or or stop eating lunch for 3 weeks and get the sp-175 plus for $750?
