I was pulling a tranny cooler and bumper from a work truck and noticed the PO had 2 ball valves, one in line with each heater hose. Anyone know why? Does the heater "leak" hot air in the cab in the summer?
This winter I had finally installed a heater core so I never experienced any hot air leakage before. If this is true, does it blend with the A/C and warm it up? In Phx I need every degree of A/C I gan get!
BTW, if I decide to do this, wouldn't one valve be enough? It doesn't seem necessary to block both hoses.
. I had to rig up some things in the air controller flaps due to old parts doing what they do best. It seems to work but I swear my vents are dumping a small amount of heat with the fan off, even if the temp is set on cold. Thought it was in my imagination, but searching around it seems this is the case with some others too.
Nevermind, I see the post above me.
