I've got a whirring/grinding noise that seems to be coming from either below the driver seat or maybe behind it. It only happens when I let off the gas after cruising around 55.
I'm not sure if its new, or if I've just quieted all the other rattles and vibrations enough that it just recently became noticeable. I did just replace the rear drive shaft u-joints, which helped with vibrations in general but did not get rid of this noise.
I'm wondering if it's the transfer case due to the driveline angles. I noticed on my slip yoke when I replaced the drive shaft that it does not go nearly as far into the transfer case as it should because of the add a leaf kit I've got on the truck. I'm not sure if that along with bad angles could cause a noise like this.
Any ideas on what it is?
