spent 30ish minutes watching Goat Rope dude, what a waste of time, he spends to much talking about what is going to come up later then actually explaining what he is doing at the moment. Watched his VCM 101, and 1.1 videos, basics right for beginners, doesn't show how to use the software, Title "VCM101" went on to make a point about using Lambda, which the transcript spells"lamda" I had to google it then sort out all the scientific hits, I understand it is another way to show air fuel ratios now, but video gave me no idea what is/was for. While it could be included in VCM101, ideally while showing how to select it or afr in the software, showing the difference in the tables, and why he prefers it over the other style.
I am trying to get the serial tach in the Ranchero working. Worked before the PO put Pertronix Ignitor conversion kit in a stock ford points dist. the owner him had converted to HEI and tach worked. At first I'm thinking the wiring is not right and searching around to see if others are having same issues. NPD video on 72 mustang very similar system, different problem won't start. Very beginning video guy is going on about doing this ohm test and showing his results, not once does he name the test or show how to set it up, just you got do it. Oh and he has 2 very different results and doesn't know why.
I am sure now our wiring is wrong. I had forgotten about the HEI conversion. So the wiring was modded for that we have 12.8 at the coil, through the factory wiring engine side of firewall, should be 7-9v. The Tach supplies the power to coil and is the resistor in the circuit. Also there is an ignition kill switch that has splice in to investigated. So will be under dash yoga time soon, just got make room for that mile long door.
