I have 4kish miles on this beast.
It had been setting an EVAP code.
I replaced the purge valve at the intake, after a smoke check showed no leaks, all was good, for a few days. Then the Mil lamp lit, I figured it was the EVAP code again. Nope O2 heater 2-1, which just happens to be the side with a manifold exhaust leak at #8.
I order 2 new gm O2 sensors from Rock Auto. Pulled the inner right fender skirt. Peeked up and saw a missing bolt in exhaust manifold. My fear was it was broken. I replaced the bolt and check as many of the others as I could get a tool on. Only the other #8 bolt was loose. I figure the gasket is bad, but fingers crossed. Even with the missing bolt it would quite down when warmed up.
Did the O2s I figured they are original, at 141k they might be slowing down. Both came out easy with an open end wrench no less.
Had an annoying drip off the oil pan, looked like oil on the ground.
Trying to pin point the source I noticed the oil pan seam was wet, from the middle of the block. This is where the water galley plug is, I had them out in July of 22. Well sprayed them both down with brake clean, hit them with a socket and long handle ratchet. Pass side was tight, got @3/4 of turn from the driver's side. Driver side was the wettest. I also suspected a small coolant leak, the bottle level has dropped a tiny bit. I figured it was a heater hose connection, since I disturbed them when doing the water pump and radiator. Hopefully this solves both the coolant loss and the drip in the driveway.
Going to replace the idler arm as well today. I thought I had ordered a pitman arm as well but looks like not.
Rotate tires, and top off fluids, maybe give her a bath.
