On startup I have no white smoke. Then after a few minutes I get white smoke. I had dropped my oil and found no sign of water in the oil. However the oil level was well above full.
After dropping the oil I set the oil level right in the middle between add and full. There is less smoke now.
I'm going to compression test the cylinders today. I hope anitfreeze is not getting into the chamber.
I'm going to remove all plugs, the red wire to the HEI and then turn over the engine a few times for each plug.
The engine has sat for several years. Any thoughts on what could be the cause of the white smoke?
