Who all Runs 10 bolt front lockers?
Check the signature:
I love the front locked. I am following Pauly's lead and putting a lockrite in the rear when I have some extra $$$.
Where did you all find the aftermarket shafts for you 10 bolts? I have looked around a good bit and cant find them. I have the 28 spline version of a 10 bolt.
The capability is nice, but I ended up going through 3 axle ujoint/ear failures, 2 shaft failures and 1 hub failure all on 37" SSR's. Ghey!
I have Yukons but I would recommend Superiors or Alloy USA. The Yukons were cheap but Yukon has had a quality control problem on occasion. There warranty is very good though. 3 years no questions.
I have seen both Yukons & Superiors broken though so for a 1/2 ton front that is going to see offroad they are not a cure all. They are a bandaid under our heavy trucks if used hard.
Harley
You can get Strange axles from ORD They are prolly the best
You can get Yukon axles from Randys ring and pinnion
Both are far stronger than stock and come with upgraded U joints for the front. It will cost around 900 to upgrade both front and rear axles. But they will be almost as strong as a D60 without all the xtra weight.
I hadn't studied that. Goooood info.:D
$900 was about 2x more than I paid. Desert Rat had an incredible price cut - don't know if it is still good.
Hey pplblazerdude
You have your E mail blocked in you profile.
Lockright 175 US Shiped
Detroit 370 US Shiped.
Let me know ASAP. I got a couple of PM's the first day I posted so I figure first reply gets them, if anyone wants them.
If you want one or both of them E mail me through my profile or let me know here.
sope said:
Hey pplblazerdude
I dont have the money right now or I would get them.
I am running the ected in the frint of mine, with 37 mtrs. I had a ezlocker befeore that with 35 mtrs. I did not have any issues (other than steering befeore I go the selectable) but I am runnin an auto trans which I think helps a lot. Just the standard ujoint change now and then. I run mostly rock and snow in cali. I am not a big user of the stupid pedal unless necessary. I drive slow and smart.
