GRINCH
Just getting back into racing again. However, I have learned a very valuable lesson. You cannot. I repeat CANNOT. build a all purpose rig and expect it to excel in all aspects.
I built the Grinch (67-72 Forum) as a multi purpose use rig. However, the competive side in me hates to lose. So I thought a mild Big block would be the ticket. I like to trail ride, Obstacle course and Sand Drag.
Questions coming in a minute!!!!
Specs on the Grinch.
1972 K5 Blazer, Full 6 point cage, 1 3/4 tube. (Not poop Pipe) NP241, Dana 60 Front, 14 SF rear, 36x13.50-16 IROKS, Eaton E-lockers front and rear. 4.88 Gears, 4L80E, Cad 500 with PJ3 fuel Injection. Racing Seats, Rock sliders, 1/4" Plate bumpers.
Total weight 6000#. Not a racing weight by any means.
We run 300' drags on courses that vary from true sand to broken up dirt.
My last runs were top speed of 49 MPH. I don't have my times with me right now and will post them later. I run in 4 low.
Without starting over how can I be more competitive in my class? I thought about shredding some easy weight before each race. I know I can drop about 800-1000# easily. Rock sliders are 1/4 wall tube double row and tied back to the frame, bumpers are made from 1/4 Plate. I think the top weighs 200-300.
I have also considered different tires. Mine are IROKs 36-13.50-16 on simulated beadlocks with Stauns.
What tire size and type (No Paddles) would work best? Right now with my gearing I cross the line at about 4500 RPM in 4 Low. If I drop down to say a 33" tire I will only pick up about 200 - 300 RPM. FYI. I Have my Trans programmed to lock the converter in WOT.
Discuss!!
Discuss!!
