Bookshelf
Registered Member
I've researched the topic a bit, and all I can come up with is a bunch of people saying it should fit. I will be purchasing a 90 Crew Cab 4x4 and am putting a Cummins in it. It has 4.10's. I already have a Dana 60 front and 70 rear with 3.54 gears. It would be cheaper to run the Dodge stuff instead of doing a ring and pinion swap. Besides, I can't find 3.54's for a 14FF. Also, I might run 3.07 diffs, which requires a different(Dodge only) housing. This is not going to be a trail rig, it will be on the road 99% of the time and has to be safe. Any help would be appreciated, thanks.
