would love to but this sucker is a lot brighter than the rest with the lowest candle power bulbs in them as i dont want to be blinded but still see them . i could try this tho and use the tie in dimmer bulb as a floor light when in use
its been soooo many years i forgot what i use to know on this stuff .
12volt gauge light CANT change the bulb and i need to dim it down a little bit .
what size resistor should i add inline to the feed for it ?
12volt and just 3watt draw rating for the system . i am thinking 1/3 down brightness and 1/2 down brightness so i have a choice .
thanks for any help .
i dont need my tach blinding me anymore in its new spot on the dash compared to the old spot .
If you can't hook up 4 wires to a module I don't see how you can get a tach wired to begin with...dude that like way more complicated than i need .
At that supply voltage the bulb is 193 Ohms, which is about a 1W bulb. Let me try a back-of-napkin calculation. For 1/2 as bright, you need about 15% reduction in voltage, which will reduce the bulb resistance by about 8.5% or 177 Ohms. So the dropping resistor would be 32 Ohms and dissipate about 1/8W, bringing the current to 61mA. That's good news because standard 1/4W leaded resistors should be OK. You could buy a pack 10, 12 or 15 Ohm resistors and start stringing them in series until the brightness matches up with the dash lights.12.86 dc volt supply for testing
200ma range scale i get 66.7 on the read out display
Website says it’s an unserviceable part and is sealed. Need to send it in for replacement if ever needed.Does the bulb come out? If so, paint it black and scrape off a little until it's perfect.
ya what he said AND i posted in the first info round . . . . .Does the bulb come out? If so, paint it black and scrape off a little until it's perfect.
ya what he said AND i posted in the first info round . . . . .![]()
