blue and green light panel lights i used in my diy4x dash build for high beam and turn lights. thay are aluminum body with threaded jamb nut on back side. thay self ground when installed with 1 center pin/screw thread for eyelet wire end for power. also the front side we see unscrews off and can change the bulb out. but the part /top that unscrews has colored lens inside of it to make the color.
bulb # GE 330 0.8watt 14 volts
body aluminum and anidized dark color almost odg green mabye or light black.
center stud/power pin is spring loaded ( sign of quality if you ask me. )
someone here asked me and i think i knew but not sure.
then someone else said possible aircraft panel / switch lights.
does anyone know ? cause i want some more .
thay are from atleast 70's back if you ask me. since my dad had them that long from what i know of. if it helps my dad use to build fire trucks in the 70's so mabye from that area of transportation ? but my dad was a horder/packrat also .
